Author Topic: Siglent SDG 1025 schematic diagram (or what is the U63 chip)  (Read 3703 times)
Offline struijsTopic starter
« on: September 09, 2018, 09:31:08 pm »
Hi guys.
I am looking for the schematic diagram for the Siglent SDG 1025.
Or, does anybody knows what kind of IC the U63 is? The letters on top does not give a hit on Google.
Thanks in advance, Peter
Offline tautech
Re: Siglent SDG 1025 schematic diagram (or what is the U63 chip)
« Reply #1 on: September 09, 2018, 10:05:13 pm »
Hi guys.
Welcome to the forum.
Have a look and follow links here:
https://www.eevblog.com/forum/testgear/the-sdg1000-and-sdg800-thread/
Some stuff seen @ HQ cannot be shared.
Offline tautech
« Reply #2 on: September 10, 2018, 08:12:22 am »
Here's a teardown thread of the SDG1010 that shows the same HW as SDG1025:
https://www.eevblog.com/forum/reviews/siglent-sdg1010-function-generator-teardown/
But where's U63 ?
Can you post a pic of your PCB ?
« Reply #3 on: September 10, 2018, 06:26:11 pm »
It is the IC close to the crystal.
Thanks for your topic link. But i can't find a schematic there.
Peter
« Reply #4 on: September 10, 2018, 06:30:29 pm »
This is the IC. Really no idea what it is.
Offline PA0PBZ
« Reply #5 on: September 10, 2018, 06:41:35 pm »
Can you maybe post a picture where we can actually read what is on the ic?
Offline tautech
« Reply #6 on: September 10, 2018, 08:57:24 pm »
Offline commongrounder
« Reply #7 on: September 10, 2018, 09:18:01 pm »
I took a peek inside my SDG1005. It looks like U63 is a HC14, a hex schmidt trigger logic chip.
« Reply #8 on: September 12, 2018, 11:55:36 am »
You are my hero!
Are there different versions of a HC14 or just one size fits all?
Thanks again.
Peter
« Reply #9 on: September 12, 2018, 12:03:18 pm »
With a little help from photoshop to enhance the letters.
« Reply #10 on: September 12, 2018, 12:05:33 pm »
It looks i have a HA14 or so.
Can you tell me exact whats written on yours please. All the letters.
Thanks for opening your device. Great service.
Peter
« Reply #11 on: September 12, 2018, 03:13:11 pm »
We are close guys. I have a better picture now.
commongrounder has a HC14, mine looks really like a HA14. Is there any difference?
And any idea where i can buy that HA14? Google is not my best friend in this.
I am from the netherlands.
« Reply #12 on: September 12, 2018, 03:14:18 pm »
HA14 and HC14 are both hex schmitt-trigger inverters. They have slightly different cmos characteristics, but function identically in most circuits. I’m guessing, due to this part’s proximity to the crystal, it functions as part of the 10Mhz time base oscillator. The other numbers on the chip are manufacturing and date codes, and will vary on a replacement part.
What specific problem are you having that has you looking at this chip? :)
« Reply #13 on: September 12, 2018, 03:19:42 pm »
I broke some legs. Don't ask me how....
So looking for a new one. You help me really a lot.
Now i have to find a reseller.
Offline PA0PBZ
« Reply #14 on: September 12, 2018, 06:07:14 pm »
First find out what the package is:
http://www.ti.com/pdfs/logic/qfncompare.pdf
Then you know what you need to order:
Part          Marking  Package
SN74AHC14DBR  HA14     SSOP-14
SN74AHC14DGVR HA14     TVSOP-14
SN74AHC14PW   HA14     TSSOP-14
« Reply #15 on: September 12, 2018, 07:19:24 pm »
TSSOP i think, its a 14 pin.
Offline tautech
« Reply #16 on: September 12, 2018, 07:30:01 pm »
They are all 14 pin, check the package type by comparing all measurements.
« Reply #17 on: September 12, 2018, 07:50:12 pm »
Thank you. i ordered 20 (!!!!) at RS-components. Lucky me they were cheap. So if anybody need 19..... :-)
Peter
Fingers crossed.
« Reply #18 on: September 12, 2018, 07:51:44 pm »
Yes, my fault. Thank you guys that you help me so much.
Mine was exact 5mm, so its the TSSOP
Peter
Offline JohnPi
« Reply #19 on: September 13, 2018, 01:32:30 pm »
While you have it open, you could upgrade the oscillator to a TCXO: https://www.eevblog.com/forum/repair/siglent-sdg1025-ribbon-cable-connector/msg1721600/#msg1721600
« Reply #20 on: September 14, 2018, 07:49:58 pm »
Hi Guys,
Thank you very much for all who helped.
I bought the HA14 IC and did some micro soldering.
The unit is working fine again including the TCXO modification.
Thanks again, Peter
