Author Topic: SMD Capacitor Value?  (Read 1203 times)
Offline Johnny10Topic starter
« on: September 13, 2018, 04:51:27 pm »
I am doing a repair and I am very confused about the on chip numbering.
A capacitor reads 226V 40372
Looking up this part I have 22uF 40Volt   ( Vishay ) ?
But another lookup reference says AVX  22uF 6Volt
Not sure which is correct.
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
Re: SMD Capacitor Value?
« Reply #1 on: September 13, 2018, 05:16:52 pm »
OK So I am not always with it !
« Last Edit: September 13, 2018, 05:30:57 pm by Johnny10 »
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #2 on: September 13, 2018, 05:24:07 pm »
It's OK Johnny10, you can still keep your membership here.  ;)
The following users thanked this post: Johnny10
Online coromonadalix
« Reply #3 on: September 13, 2018, 09:09:07 pm »
To be sure  measure the supply voltage(s) ... and choose the right vcc specs
Offline PKTKS
  • Country: br
« Reply #4 on: September 14, 2018, 11:11:41 am »
That is a smart decision *BUT*  it will not solve the overall problem
It has become an increasingly  and dangerously problem to deal with todays
"MODERN"  part  descriptors.
OLD SCHOOL parts are responsible marked and chances to make mistakes are small
What will prevent a mistaken part being fitted at production as these "MARKS" or codes
are absolute obscure and non trivial ?
The result of a BAD MLCC  just exploding with a 9V bat change.
From a DMM, removed the old... inserted the new BAT .. power .. BOOM!
I can read like xx06 from what is left but without the proper voltage rating...
Only your advice of measuring to be sure.  Yes it makes sense - each day more sense
I did that to replace that with a proper robust THT
SMD has become a dangerous stuff. like this one
« Last Edit: September 14, 2018, 11:13:29 am by PKTKS »
