Hi everyone!
I've recently bought my first oscilliscpe (a Hameg 203-4) from ebay, which unfortunally has one defective channel. When powering it on it does not show any trace for the first channel, the second channel seems to be working fine. Here some resources for others working on that model:
Service Manual and Schematics: https://www.eserviceinfo.com/downloadsm/65162/Hameg_HM-203-4.htmlAfter not seeing any obviously defective components I started by disconnecting the preamplifier (manual page 38) of the defective channel and after powering up, there is a trace!
So it seems like the problem is on the preamplifier board. To validate that I disassembled the scope, which turned out to be more challanging than I anticipated, and swapped the preamplifiers for channel 1 and 2. Afterwards a test showed the 1st channel working and the 2nd channel being defective, which seems to confirm my assumption.
I now measured various parts of the preamplifiers with a multimeter, without finding anything broken. Since there's quite a few socketed parts I decided to simply swap those to identify the broken component, which turned out to be T100/T150, a U441 dual JFET N-Channel Transistor e.g.:
https://www.digikey.de/product-detail/en/vishay-siliconix/U441/U441-ND/4496477Now here's my issue: I neither found any place where to order one of those, nor did I find any obvious alternative (e.g. using the according search function from digikey). I'm still far from an expert in electronics and honestly can't really tell why a JFET was used instead of a "regular" transistor or a MOSFET and what the exact differences are. I did boldly try to simply throw in two N-Channel MOSFETs I had available (IRF3205) in there matching the Gate/Source/Drain pins, without any success. (I did not expect that to work, but I thought it was worth a shot
Can someone help me figure out what kind of transistors I need to order to fix that issue and/or tell me how to figure that out by myself in the future?
Disassembly instructions1. Remove the screws on the back and remove the back cover2. & 3. Stand the scope on the back and pull out the electronics upwards (grab on the front panel) and put the cover away4. & 5. Remove the caps of all small knobs and unscrew+remove them, then unscrew the big knobs and remove those as well. (This is what took me a while to figure out)6. Remove the 6 screws at the edge of the front panel7. Unsolder the ground connections and remove the front panel a bit, then unsolder the other cables and remove it completelyBest regards
Jens
