Well, that's true. Using ohm's law you can figure that out. I think I was being TOO general with the dim bulb. The idea is to use a lamp of high enough wattage to power up a device but avoid catastrophic failure. Yes, it will reduce voltage depending on current drawn, but choose enough wattage it's within reason.
In general, devices that are small current draw and transformer isolated like a tape deck.... I use my metered variac at 115 v and check for abnormal current draw.
Point is, some things do not like being powered up this way, as the IC's can lock up in a bad state, drawing far more current than normal because they don't power up in a "reset" state.
It's a judgement call. Tube gear? Bulb or variac is totally fine, as is most old transistor gear.
But be careful with Microprocessor stuff.
