Author Topic: Hakko FM-203 error code C-E on port D (solved)  (Read 1342 times)
Offline FatMexicanTopic starter
« on: May 12, 2024, 11:39:29 pm »
I am getting an error message of C-E (only on port D )on my FM-203 soldering station.  I have tried multiple soldering iron in the station (FM-2023 and FM-2030) and get the same error message.  Port S works correctly when I plug in a FM-2027, but the FM-2027 will get the error message C-E when plugged into port D.  Any suggestions?
Thanks for your help
Pedro
« Last Edit: May 13, 2024, 10:28:57 pm by FatMexican »
Re: Hakko FM-203 error code C-E on port D
« Reply #1 on: May 13, 2024, 10:28:02 pm »
It was a user error I was not using  both ports, now that I have two soldering irons everything is fine.  |O
Pedro
