Author Topic: Is my common cathode diode assembly broken?  (Read 1000 times)
Offline scsiTopic starter
« on: July 24, 2019, 07:24:10 am »
Hello all,
I am testing ultrafast rectifier diode with DMM (internal schematic attached)
pins 1 - 2 reads diode drop (0.6V) reverse (infinity)
pins 2 - 3 reads diode drop (0.6V) reverse (infinity)
pins 1 - 3 reads short
Is this a normal behavior?
« Last Edit: July 24, 2019, 10:31:32 am by scsi »
Offline daqq
  • Country: sk
    • My site
Re: Ultrafast Rectifier
« Reply #1 on: July 24, 2019, 07:35:55 am »
Should not be. Are you sure you have the right diode?
« Reply #2 on: July 24, 2019, 07:46:52 am »
original part in question is U1640G in TO-220 package and it is from SMPS so it must be ultrafast rectifier  ^-^
desoldered one pin and it still reads short accros 1 - 3 pins.
Offline ogden
  • Country: lv
« Reply #3 on: July 24, 2019, 07:59:37 am »
Oh, you are measuring in-circuit. Then your initial measurement was OK because often those diodes are used in parallel, pins 1-3 tied together. Why you still measure short between anodes - dunno. Perhaps you think you desoldered one pin but actually did not?
« Last Edit: July 24, 2019, 08:01:32 am by ogden »
« Reply #4 on: July 24, 2019, 08:41:14 am »
Might be, these double sided commercial pcbs are pain to desolder without damaging the pads.
Thanks for the info!
Offline exe
  • self-educated hobbyist
« Reply #5 on: July 24, 2019, 09:28:20 am »
I propose title "is my common cathode diode assembly broken?".
Offline David Hess
  • DavidH
« Reply #6 on: July 24, 2019, 02:27:44 pm »
Or the two diodes are connected to different points on the same transformer winding producing the same result.
The following users thanked this post: ogden
