Author Topic: Just What Is Uncle Lo Soldering With - CE IR Thermometer Repair  (Read 4914 times)
Offline SgtRockTopic starter
« on: December 04, 2012, 03:45:39 pm »
Greetings EEVBees:
--Just what in tarnation is Uncle Soldering with? Goats Milk. This (see pictures below) CE Infrared Thermometer was working fine when I put it away a few months ago. When I went to use it, this morning, the battery was kaput, and it still would not fire up even with a new battery. When I took it apart there was a whitish gunk all over the circuit board. Several good cleanings with rubbing alcohol and an old tooth brush, restored full functionality. It agrees fairly well with my Fluke 87 with K type thermocouple.
"Happy for you to desoldering, please."
Wun Hung Lo 1948 -
Best Regards
Clear Ether
Offline free_electron
    • SiliconValleyGarage
Re: Just What Is Uncle Lo Soldering With - CE IR Thermometer Repair
« Reply #1 on: December 04, 2012, 04:23:29 pm »
Ah .., harbor freight quality.  I got one too ... It works fine but it sucks the life out of the battery , even when off ...
Offline Shock
« Reply #2 on: December 04, 2012, 04:43:23 pm »
I'd like some of that with my flux residue sugar and cornflakes
« Reply #3 on: December 04, 2012, 06:00:02 pm »
The best quality non residue solder, at the lowest price of course.................
Offline DavidDLC
« Reply #4 on: December 05, 2012, 12:17:21 am »
Time to turn on your variable power supply, set your multimeter and make some current measurements of the unit in standby !
Online tom66
« Reply #5 on: December 05, 2012, 02:27:20 am »
I have the one-hung-lo one from China, around £10 on eBay.
Within about 1deg of my thermocouple so that's good.
Rated to 380°C, but got it to measure a burning wood fire at >560°C before it showed overrange (all dashes on display.) Not sure if accurate -- but it meets specs.
Stby consumption is about 1uA, pretty good, and only 10mA running. Should work for some time. One thing you must look out for. If you plug in new battery but DON'T press the trigger it draws ~5mA continuously in standby. Once you press the trigger, the thing wakes up, about 30 seconds later it then goes into sleep mode when it draws the ~1uA. Seems processor doesn't enter sleep mode until it shuts down first time.
« Last Edit: December 05, 2012, 02:29:14 am by tom66 »
« Reply #6 on: December 07, 2012, 04:36:33 pm »
Dear Tom66:
--I decided to check my CE Brand for current, as well; Standby 80 µA, Trigger Down w/laser 22 mA, and Trig Down wo/laser 11 ma. I used two different Fluke meters to be sure. In any case I am storing mine with the battery out. I think I will buy one of the new super cheepies from Uncle Lo, for comparison. I will report back.
"Measure twice. Cut once"
Norm Abram 1950 -
Best Regards
Clear Ether
« Last Edit: December 08, 2012, 12:21:54 pm by SgtRock »
Offline T4P
  • Country: sg
    • T4P
« Reply #7 on: December 07, 2012, 05:59:45 pm »
W/o laser 110mA?  ;) that's not right eh.
11mA you mean? My Cheapie from DX that i bought for 16.99USD is called the Benetech GM300 (If you search elsewhere, GM300) but it feels pretty decent though but it seems impossible to take apart
« Reply #8 on: December 08, 2012, 12:21:07 pm »
Dear T4P:
--You are, ofcourse, correct Sir. I will modify my post. Thanks
Norm Abram 1950 -
Best Regards
Clear Ether
