Test for shorts on the power rails?Usually If a GPU was giving me issues I would re-flow the GPU and it has solved many issue in the past ( but this is only when the card boots and has issues with display)Best of luck.
And I cleaned and put in to Test and …… smoke and sparks ⚡️
might be something small pulling down the voltage and making the card short the motherboard
Quote from: CAPSBOY on February 08, 2023, 10:59:01 amAnd I cleaned and put in to Test and …… smoke and sparks ⚡️Looks like there was a shorted ceramic cap which was very easy and cheap to replace. But now it's probably a PCB burned through he layers. Clean that and post a photo of how bad it is.Quotemight be something small pulling down the voltage and making the card short the motherboardYou are not supposed to power a graphics card which makes computer to turn off unless you want to cause more damage.
