Author Topic: Teardown & Repair of an Agilent E4440A 3Hz - 26.5GHz PSA Spectrum Analyzer  (Read 1416 times)
Offline HugoneusTopic starter
    • The Signal Path Video Blog
You can watch the video here: [21 Minutes]
youtu.be/7YYcO-xkmO4
More videos at The Signal Path:
www.TheSignalPath.com
The following users thanked this post: rhb, Bud, Samogon
Offline Samogon
I think no chance to repair those relays even after you torn one open.
Offline texaspyro
One should never handle watch/memory batteries with bare hands.  The oils and salts in a fingerprint across the cell can discharge the battery faster than the circuit.  I also always clean my cells with IPA before installing.
Offline TiN
  • Country: ua
    • xDevs.com
I think Hugoneus confused a little pinout on relay when talking about it. Coil drive pins are on same side as center "RF input" contact :)
Nice video, I add vote comment to see video on how to simulate RF components in software. Are there any "hobby"-level RF field simulators? :bullshit:.
I think you might be right about the pins. :) I was traumatized about my tool breaking.  |O
Haven't found a good hobby 2.5/3D simulator yet.
