Thank you for the responses.
I have attempted to follow the isolation/troubleshooting steps in the O-scope troubleshooting. I will continue to review that and the service manual as a I get more bits of information to apply to the text.
Yes the intensity is adjustable.
a short around c1427/r1427/vr1428/crt mesh, or
All components seem to be good. However the voltage across vr1428 is about 80v on start up and drops to 30v after a second or two.
I did not get a voltage going from r1428 to ground. I would have expected 300v there. Correct?
I disconnected the CRT at the neck and no change in voltages.
TP1518 is low at 107.9v
TP1568 is high at 0.79v
What are the chances I will blow up my Fluke 179 DMM poking around the HV supply?
I will take the new found info and go back to the manuals.
