Assuming none of the corners or edges are tucked under, a quick check with a DMM of the resistance between the top surface of the tape and the adjacent chassis would tell you whether it has conductive adhesive. The top left corner looks a little dodgy, so if you get a low ohms reading, lift the tip of the corner slightly with a scalpel and re-test
