Author Topic: Schematic help!!!  (Read 348 times)
Offline CramboneTopic starter
Schematic help!!!
« on: July 12, 2024, 09:49:07 pm »
Can anyone tell me where the 26VDC starts and the path it takes by looking at this Power Supply Schematic?
Thanks, Andrew
Offline Harry_22
  • Country: hn
Re: Schematic help!!!
« Reply #1 on: July 12, 2024, 10:05:39 pm »
Your PS has PFC circuit. 26 volts takes from U2 T2. This is some kind of standby voltage.
The following users thanked this post: Crambone
Offline asis
  • Country: ru
« Reply #2 on: July 13, 2024, 12:52:42 am »
Apparently this is the PS RPS-1500-xx MEAN WELL line.
U7 (pin2, J2_2) gives +5V SB.
T3 (TIP122 Darlington) forms from +26V -> +13V to power the drivers U9 & U10 [Vcc 3] (UCC27424 s) of the inverter itself Q13;Q14;Q15;Q16 and has a switching circuit (HV-ON) Q11;Q12 that controls PWM module (PCB1 DC1500_CNTRL_BORD).
Q17; SCR1 & ZD1 - OVP.
It would be interesting to see the diagrams of the PFC & PWM modules themselves.
Offline Kim Christensen
« Reply #3 on: July 13, 2024, 12:57:39 am »
Don't start multiple threads on the same topic! I already told you this in the other thread.   |O
