My A/C (aircon, air conditioner) stopped working earlier this week. The blower (air handler, really my furnace that I use as a blower in the summer) wasn't working. I found the furnace was pretty simple - one circuit board. I found the motor relay. I toyed with the idea of taking the board out and seeing if I could fix it.
Instead, I decided that because I'm not an A/C technician and never have been, I'd call in a pro. The guy came out, and agreed with me that the board was bad. I had them order a new one. It was expensive, almost 600 USD. (I bought one from the furnace manufacturer, via an authorized dealer. I didn't want to chance an aftermarket, used, or "ebay new" board, although there was an e-bay seller selling one.)
When he came back to install it, I asked if I could have the old board. He said the old one wasn't required, and I could keep it. It had a plastic bracket that I had to drill off to get to the trace side of the single sided board. The attached picture is what I found. It's not the best picture, but I hope you can see what looks like part of the trace that has broken off and still attached to the relay pin, and an annular air gap between that and the board. The edges are jagged and there is evidence of heat with some black residue on the board.
However, when I removed the relay, I found that wasn't the case. It was just a solder ball. The board is fine. I could have fixed the thing with less than a minute of work. (desolder, clean, re-solder)
I suspect that the solder joint was poor from the factory, causing a high resistance that heated the solder and caused it to drip, but I really don't know. The rest of the components in the blower motor circuit (board terminals, other component leads) are undamaged with no evidence of heating from over current. So, I'm really at a loss to explain what happened.
At least I have what I believe to be a good spare. I won't know unless it fails again, as I have no intention of taking apart my working furnace. (yes, I know. I'm turning it on instead of taking it apart.)
I suppose I should have been bolder.
