Author Topic: LIDL bug zapper not working  (Read 1944 times)
Offline Zero999
  • 0999
Re: LIDL bug zapper not working
« Reply #25 on: August 10, 2024, 07:24:59 pm »
A magnetic ballast is definitely the way to go. Fluorescent tubes don't do very will with capacitive ballast at mains frequencies. Every time the voltage reaches the tube's striking threshold, a very large current spike flows, through the capacitor, which shortens the life of the tube. An inductor has a high impedance to sudden changes in current, which prevents current spikes.
If you want a more powerful zapper than use larger capacitors and add more stages for a higher voltage and current.
How about ditching the fluorescent tube and replacing it with LEDs? They'll have no problem with a capacitive ballast. You could solder SMT parts in between the tracks of some stripboard.
Offline soldarTopic starter
« Reply #26 on: August 10, 2024, 07:56:32 pm »
At this point the value of all this is anything I learn because these devices cost close to nothing.  I need to leave this thing alone because the quality is not good and, for example, the helicoidal zapping wires are aluminum and break easily from flexing.
Magnetic ballasts are better at smoothing current but they consume quite a bit of power and let it off as heat.  I guess that is why they also put a resistor in series with the capacitors.
With what I know I feel I might attempt to build a new one or rebuild an old one. The voltage pump is easy and the light can be anything.
In my repairs of different products I am finding quite often a certain incompatibility of components which are technically good and are supposed to be good.
For example, I have USB cables and chargers which are all good but they might not work when coupled in some way so I have sets of cables and chargers assigned to each device and I know they work.
Also with components in devices. Components A and B should work together but they don't. Components A' and B' from a similar device do work. I exchange B with B' and now everything works. It is probably a matter of marginal specs.
I think this is probably the case here. The tube is not bad, the starter is not bad but they just don't work together. Probably a matter of specs being at the limit or outside.
Also, probably the device was tested at the factory and worked well.  But maybe now I am using it with different voltage, different temperature (it is extremely hot here), who knows what else may be different.
« Last Edit: August 10, 2024, 10:09:05 pm by soldar »
Offline jzx
« Reply #27 on: August 15, 2024, 03:30:54 pm »
You can try to put a wire along the tube, against the glass, connected to one of the electrodes with a 1 Mohm resistor.  It can be a thin wire coiled a few turns very spaced. This trick was used in very old fixtures without coil. The resistor is for safety if somebody touches the tube, in your case .. but put anyway
Online themadhippy
« Reply #28 on: September 29, 2024, 07:01:10 pm »
« Reply #29 on: October 07, 2024, 01:41:47 pm »
Yes. That's the exact same one. I wish he would have done it a few weeks earlier as it would have saved me a lot of work.
At any rate, now I have two units stored away waiting for next year's season.
