Use your multimeter.
What is the DC voltage at the cable plug? Once you are sure the power supply is working we can talk about the rest.
Check the resistance between + e - at the DC jack at the Laptop Mainboard. Do you have a short circuit?
If everything looks good plug the cable into the Laptop and maybe check if the DC voltage is incoming at the mainboard as expected...
