Author Topic: unknown mosfet 2521A?  (Read 1377 times)
Offline hercegovacTopic starter
« on: June 08, 2019, 09:52:11 pm »
any help figuring our replacement component for the part labeled 2521A will be appreciated .
Offline Chriss
Re: unknown mosfet 2521A?
« Reply #1 on: June 09, 2019, 06:28:08 am »
Hi!
Can you pls give a description about the circuit where this mosfet is located?
Or maybe a drawing?
Sent from my SM-J500F using Tapatalk
Re: unknown mosfet 2521A (Godox AD200)
« Reply #2 on: June 10, 2019, 04:00:54 pm »
So it is a control board for GODOX AD200 flash. Image of the control board is attached, the mostfet when measured with Voltmeter shows short between gate and source (assuming it is mosfet).
Offline Chriss
« Reply #3 on: June 10, 2019, 04:18:50 pm »
Take it out from the board and check it if it is still in short.
Make a picture of the region so we can try to flow the wiring/trace..
Offline fzabkar
« Reply #4 on: June 11, 2019, 04:13:15 am »
26Z08 appears to be an LDO regulator (there are large capacitors on each pin). AFAICT, both parts have circuit references of the type "Unn", so they must be ICs. I suspect that 2521A could also be an LDO. Do the Vouts go to the Vcc pins of the other ICs?
