Author Topic: Focusrite scarlett 2i4 1st GEN component Missing  (Read 972 times)
Offline marcosboieroTopic starter
  • Country: ar
« on: April 12, 2022, 07:09:55 pm »
I all, i have a issue, my scarlett fall to the ground and now theres some componet missing, i found a previous post and i could find the name and the values of one of them, i still have one component missing in the board apear like 137, could anyone knows what the component is, and what value?
thank in advance, sorry for my english i will post a picture from the location of the missing component
  • Country: ar
Re: Focusrite scarlett 2i4 1st GEN component Missing
« Reply #1 on: April 12, 2022, 07:12:46 pm »
the missing component is marked in light blue   :scared:
Offline SiliconWizard
« Reply #2 on: April 12, 2022, 07:40:53 pm »
C137, pretty much looks like a bypass ceramic capacitor. Considering its apparent size (I'd say 0805), I would guess that it may have a higher value than your typical 100nF bypass cap. Possibly something like 1uF or 10uF ceramic.
Offline fzabkar
« Reply #3 on: April 13, 2022, 03:54:05 am »
Can you locate a datasheet for U4? If it contains an application circuit, that should tell you what the function of the capacitor could be.
Offline EEVblog
« Reply #4 on: April 13, 2022, 11:49:46 am »
Yep, get the app in the datasheet for the chip.
You could also buzz out the lines and see if they are GND and VCC to determine if it's a bypass cap or not.
But if it was a bypass cap then it's actually rather unlikely that the thing would stop working if it's missing.
Offline Deimos
« Reply #5 on: April 15, 2022, 08:49:22 pm »
You could try sending a message to Focusrite support inquiring about the component(s) in question.
I contacted them in 2014 or so, about a schematic for my Scarlett 8i6 1st gen, as it too had a broken USB port, and a couple components were lost from the damage. At that time they were willing to send me a schematic, but only if I signed an NDA. I said that was okay, though to make it easier I only needed to know the value of a couple parts, didn't need the entire schematic, and gave the parts location, and tech support was gracious enough to look it up for me. One was a 1uf capacitor around the USB connector area, and a small choke for the USB line. I still use the 8i6 today.
I don't know if they will still do this, but it wouldn't hurt to ask them. I was kind of surprised they helped out like that, but they did, of course that was 8 years ago.
« Reply #6 on: April 15, 2022, 11:15:56 pm »
True. But we don't know if the thing has "stopped working", the OP just said it has a component missing. So we don't actually know what the symptoms are if any. (Unless there was another thread about it that I missed.)
