If you are trying to diagnose a problem it is always good to start with the symptoms. If the blade seems stuck and hard to turn, then most likely the problem is mechanical--a sticky or jammed bearing. If the motor hums when you turn on the grinder, but the bade doesn't turn, this would reinforce the stuck bearing hypothesis and suggest the problem is not electrical.
What happens if you apply 230 V power to the motor after cleaning and lubricating the bearings so it turns freely?
