I recently acquired a Fluke (Philips) PM2811 DC power supply. Unfortunately, the previous owner had failed to properly seat one of the PCBs. So when I slid off the cover for the first time, a small transformer on a daughterboard caught against the cover and underwent rapid unscheduled disassembly.
Service manual link is below. The daughter board is on the PCB layout on page 56, labeled T101. The wiring diagram on page 57 lists it as "7105-2 EL Inverter DC 5V / AC 115V".
https://www.eevblog.com/files/philips_pm2811_pm2812_pm2813_sm.pdfLong story short, it seems that this is a 5vdc to 115vac inverter that outputs to "VBL+" and "VBL-". I'm assuming BL is backlight?
Is there a module that I can substitute in here? I'd reverse engineer the daughter board, but the transformer is in pieces and has no markings.
