After replacing mcu(Megawin) on imax B6 the main battery port measures a 8.32volt battery as 17.30volt, but if balance is connected each cell is measured correctly. Something must have burn in the circuit but cannot find. Can anyone help me, i attach the Imax B6 mini(same for ACV2) schematic to see. If any one sees what component would be faulty please help.
