Author Topic: Fluke 8845A 8846A Electrolytic Capacitor Replacement  (Read 912 times)
Offline gogomanTopic starter
« on: December 27, 2022, 03:54:02 am »
Hello all,  What brand/series of cap's did you use and would you mind sharing the BOM.
thanks gogo
Offline Miti
Re: Fluke 8845A 8846A Electrolytic Capacitor Replacement
« Reply #1 on: December 28, 2022, 12:20:12 am »
Did you measure them and concluded that they need to be replaced? I remember measuring some in my 8845 and the conclusion was-don’t touch them.
Fear does not stop death, it stops life.
Online gamalot
  • Correct my English
    • Youtube
« Reply #2 on: December 28, 2022, 10:35:59 am »
Yes, why replace them? Inside my Tektronix 4040, the plastic jackets on those electrolytic capacitors shrank a lot, look ugly, but they seemed to work fine.
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
Offline coromonadalix
« Reply #3 on: December 28, 2022, 04:45:01 pm »
Good brand is Nichicon
I recapped my 3x 34401a meters with them,   for the tantalums    can't remember, they where way older than  theses meters  loll
But  if the meter work okay   there is no rush,  you need very good skills and the proper tools ...
The following users thanked this post: gogoman
« Reply #4 on: December 29, 2022, 02:27:26 am »
I would not replace them if I did not need to
BOM (to be confirmed)
   Value          Voltage       qt       Comments
   15000uF     16               1          TH
   6800uf      10               1          TH
   47uf        100                1          TH
   220uf       50V               2          SMD
   1000uf      10V              1          SMD
   2200uf      35V              2          ?
Is the voltage rating of the 220uf and 1000uf correct, attached are pic's
thanks
Offline Miti
« Reply #5 on: December 29, 2022, 03:18:04 am »
My go to brand/series for recaping instruments is Nichicon PW. I used them in switching power supplies and main boards and they never failed me. I recaped oscilloscopes, lcd monitors, signal generators.
