Following. (I recently found an 867 at work in storage, and it's also not working. It'll power on in some ranges, but is often on the wrong range, and the display has glitches. I cleaned the rotary switch and it made no difference, so I think it's a logic issue. Didn't have a chance to check voltages or anything, and I've put it back in storage for now.)
