Hi all. I haven't done any repairs for a long time, thought I'd dust off my skills with a really tough one.
A Bearcat 996XT radio scanner that got fried by a surge or maybe incorrect power supply.
I have no service information, would love to find a schematic, but nothing found so far.
Some fried input circuitry was replaced before I got it. I replaced an open 2.2 ohm resistor so far.
Symptom is, it's dead
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Looking at supply voltages it has 6v, is missing 8v and missing 3.3v for the CPU area. I think the 3.3v regulator is fed by the 8v supply, so not surprised it's missing.
My specific question for now, is about the 8v regulator. A 78R08F 5 pin TO-252. It's running pretty warm, and only outputting 2v.
Looking at the datasheet, Pin1 is input, Pin2 gnd. Pin3 output, pin 4 is NC, and pin 5 is on/off control.
Here's the thing, pin 2 reads 10vdc referenced to chassis gnd. And pin 2 doesn't appear to be actually connected to gnd on the pcb.
Not sure if this is a multi-layer pcb, pin 2 goes to a via, haven't really tried tracing it too far.
So, am I looking at an inaccurate datasheet, or is there something weird about this design?
I removed it, and measured the output pad on the PCB, and it's not shorted or particularly low resistance. 12v on pin 1 and still 10v on pin 2 with the regulator removed. Will test the regulator soon.
