Author Topic: BECKMAN CIRCUITMATE AM12  (Read 602 times)
Offline lionelkjhTopic starter
« on: October 27, 2022, 08:19:11 am »
Hi there! I am looking for the diagram of the BECKMAN CIRCUITMATE AM12 multimeter: could someone help me?? Thanks in advance! (view the photo) :-//
Re: BECKMAN CIRCUITMATE AM12
« Reply #1 on: November 05, 2022, 09:16:51 am »
sniff :scared: :scared:
Online Gyro
« Reply #2 on: November 05, 2022, 10:01:39 am »
I can't see whether this is a passive moving coil multimeter or whether it has active electronics to increase the ohms-per-volt input impedance. The image is low resolution so trying to scale up the image doesn't help.
Analogue meters lilke this are usually fairly simple internally (single or double sided PCB, through hole components) and it is relatively easy to reverse engineer the schematic. If you are trying to debug specific problem, eg, current, voltage or resistance functions then tracing those specific areas should reduce the task.
Edit: A quick web search revealed some information, it is an active meter using a pair of descrete jfets in a bridge configuration... https://worldradiohistory.com/hd2/IDX-UK/Technology/Technology-All-Eras/Archive-Practical-Television-IDX/90s/Television-Servicing-UK-1993-03-OCR-Page-0036.pdf
Non of the usual manual sites seem to have anything and I can't find any internal photos.
« Last Edit: November 05, 2022, 10:15:53 am by Gyro »
Best Regards, Chris
Offline Chris56000
« Reply #3 on: November 05, 2022, 08:38:29 pm »
Hi!
This meter is a clone of the Huang Chang HC–5050E & you can get a booklet with a circuit diagram and component list in the back from Elektrotanya here :–
https://elektrotanya.com/altai_hc-5050e_analog_multimeter_sm.pdf/download.html
Chris Williams
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
« Reply #4 on: November 06, 2022, 05:48:14 pm »
THANKS A LOT!! :-+ :-+ :-+ :-+
