Author Topic: Fluke 87 IV - repair log  (Read 12335 times)
Offline Mr. Scram
  • Display aficionado
Re: Fluke 87 IV - repair log
« Reply #25 on: January 19, 2019, 12:15:08 pm »
very nice repair
Usually we throw meters away when they don't work anymore
Really? I'm sure there are many loving homes to be found here. ;D
Offline psykok
« Reply #26 on: January 19, 2019, 12:44:01 pm »
very nice repair
Indeed
Online coromonadalix
« Reply #27 on: January 19, 2019, 04:09:07 pm »
How did you get the rupper case such clean?
I have a similar looking Fluke 87.
/PeLuLe
A good way to clean this cases is to use WD-40.
Looks strange but trust me it's working.
Alex
I would not use any petroleum or sillicone based solvent   not wd40, gigaloo  etc ... it may attack the yellow plastic surface in time.
Offline shakalnokturn
« Reply #28 on: January 21, 2019, 10:57:18 pm »
Nice restoration!
I find it very odd that you should have the Panasonic backup capacitor in there. The 87 IV isn't meant to have data logging the 89 IV is the variant that does.
I have a 187 (same as the 87 IV) that was in the normal situation, not having the backup cap, and that I have converted by adding the missing components to change it to a 189.
Did you by any chance remove the LCD during your clean? I'm curious to knowing if there was a  SRAM IC under there and if there was what reference it was.
My topic on the conversion:
https://www.eevblog.com/forum/testgear/fluke-187-dmm-upgrade-to-189/msg1390658/#msg1390658
Offline tooki
« Reply #29 on: January 24, 2019, 06:56:07 pm »
/PeLuLe
Alex
Flukes are made for industrial use (in the serious sense, not marketing wank). If they were susceptible to any common solvents, it would be widely known. I think any household solvent is going to be totally okay.
