Author Topic: Power supply PWM  (Read 816 times)
Offline Megael9Topic starter
Power supply PWM
« on: November 26, 2021, 03:52:17 am »
Hello every one,
I’m currently working with a power supply which  uses a microchip to generate the PWMs signals, however only one of the two signals is present at the microprocessor. My question is, can I use an inverter chip to generate the missing signal?
This signal goes from the microchip to a driver chip part # ir4427 which drives the power supply Mosfets.
Thank you
Offline ambrosia heart
  • Country: hk
Re: Power supply PWM
« Reply #1 on: November 26, 2021, 12:42:18 pm »
Don‘t do that.  :phew:This PWM signal is controlled by the voltage output via photo-coupler and TL431/KA431. Detailed explanation see pm. :popcorn:
« Reply #2 on: November 26, 2021, 03:15:45 pm »
Hello and thank you for the quick reply.
The manufacturer will not sell me the microchip for this power supply.
Is there any suggestions for this problem.
Thanks again
  • Country: hk
« Reply #3 on: November 26, 2021, 11:16:19 pm »
Don‘t worry.  :)  Taobao :-+ can help you.  Find friends living in
Hong Kong or Taiwan to help you to buy one to fix this
stuff. They are at cheap price. :D I repair AV amps at components level. All components come from taobao. :popcorn:
All work well. If I were you, I will choose 4-6RMB to buy.
See photos. :popcorn:
