Author Topic: Help with vintage HP 3000 series30/33 computer  (Read 2365 times)
Offline m k
Re: Help with vintage HP 3000 series30/33 computer
« Reply #25 on: January 16, 2021, 01:17:19 pm »
Bench is good.
Then you can change analyzed points and check easily even single gates if needed.
The board is also practically logic chips so ESD protection is not so vital as it could be.
Your installation seems to be as it should.
If something is sticking on you when you leave that lesser part will fall first.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
