In section 9 of the 2465 manual there are error diagnostic flowcharts. I am assuming that the 2465A is similar. Would be worthwhile to check. Edit.....does that scope have the DMM option? If yes you may also need the 2465A Options Service Manual. Make sure it's for the "A" suffix and not the "no suffix" or "B" suffix. There are significant differences.
