So a little bit ago I decided to upgrade to a dual channel PSU and bought a 3005F-3. As far as I can tell, it appears to be identical to the one jamesp15 did a teardown of
here but where it should say "Mastech" on the front, it says "Dr. Meter" (might be part of the problem). You can imagine my disappointment when after only a few months it decided to not power on.
I cracked the cover and saw bits of "stuff" rattling around inside the case - never a good sign. Sure enough, one of the components appears to have failed violently (see pictures). Fortunately, the component was still intact enough to make out the "NTC" on it, so it's clear it's an inrush current limiting thermistor (in case the fact that it was in series with the primary side of the transformer wasn't enough of a clue). It should be easy enough to replace, but the remainder of the markings are completely gone, so I'm not sure what resistance/current rating it was.
So here's the question: Does anyone know what specific type of thermistor this should be? If anyone has a similar model, it should be pretty easy to open it up and read the markings off the thermistor. Or if anyone is familiar with PSU design and can recommend a part, that would be helpful too. And if anyone has a schematic showing the thermistor value, that would be really awesome! (I scoured the interwebs, but couldn't find one for this model.) A few points of info that may be relevant: 1) I'm in the US, so I'm running off 120 VAC. 2) It has a max output of 5A at 30V x2 channels = 300W. 3) It has an 8A fuse on the mains, so the thermistor obviously doesn't need to sustain more than that in steady state.
One other side issue - as you can see from the pics, one of the caps (C3 - an X capacitor) was torched pretty bad as well, so I'm planning to replace that too. The markings on that are also illegible, but I think I have a pretty good idea what to put there. I opened my old single channel Mastech and that had a 10nF 2KV rated cap across the mains, so I'm planning to go with that (no thermistor in that one though). But if anyone can tell me exactly what that cap's supposed to be, that would be appreciated too.
