Author Topic: ID thermal fuse  (Read 485 times)
Offline GLouieTopic starter
ID thermal fuse
« on: November 11, 2019, 05:59:18 pm »
I want to ID a thermal fuse/thermal cut out to verify replacement specs.
It's from a mini convection oven used for ski boots, TFHS-2 made in Germany by K-Tech; I have the USA version. Fan operates, but no heat, and the TCO is open. It apparently ran fine for years, then quit. The heating element is stamped 1600W at 115v. There is a heat control with thermo sensor in the cavity.
Pic attached, there is an "E" logo, Tf 141C, D139PT UH
I searched, but did not find OEM specs. My plan is to use a NTE 8139 (141C, 15A) as it is common in the USA.
« Last Edit: November 11, 2019, 06:06:46 pm by GLouie »
Offline rvalente
  • Country: br
Re: ID thermal fuse
« Reply #1 on: November 11, 2019, 07:20:24 pm »
I could not identify it either but, 145C sounds good enough for me.
