I replace C227 and C248. Still same same behaviour. I cleaned the board further.
Here are pictures of the current state:
![Roberts Expression DAB/FM Radio fault finding and repair 2084624-0](https://www.eevblog.com/forum/index.php?action=dlattach;topic=421370.0;attach=2084627;image)
![Roberts Expression DAB/FM Radio fault finding and repair 2084630-1](https://www.eevblog.com/forum/index.php?action=dlattach;topic=421370.0;attach=2084633;image)
Furthermore i tried to identify the ICs in that area. My findings
P0SV - RP200x SERIES Voltage Regulator
P0SV_rp200_ea-3219765.pdf (457.49 kB - downloaded 30 times.)
4013B - CD4013B Dual D-Type Flip-Flop
4013B_cd4013b.pdf (1203.32 kB - downloaded 10 times.)
26 A6K - AAT600 High-Precision Reset Voltage Detector
26_A6K_AAT600.PDF (336.32 kB - downloaded 16 times.)
29 8T - XC6202 High Voltage Positive Voltage Regulators
29_8T_XC6202_001.PDF (1858.46 kB - downloaded 14 times.)
I hope I am not too far off. I have no idea what the two "M6"s are and the "L6".
I measured the CD4013B and i didn't read a signal with my scope on the clock inputs. Is that normal?
Since all buttons are working except of the power button I will try to desolder this one. There was a lot of leaked stuff on this button.
There is a component missing above the "P0SV" voltage regulator. Can it be blown off? Dematerialized to dust?!. Or just an empty spot on the PCB?!
I really appreciate your inputs.
