My opto isolator story on the analog PCB is that M2 seems to only be required to work at initial power-on. On at least two different units that were warmed-up in one location, then powered down and move and powered back on, they both initially detected the option boards but not when powered off and powered back up. M2 had to cool back down awhile before it would work again, and I wondered if it was "selected" on purpose and I also wondered if those dots meant different degrees of degradation. If different color dots could be put on ICs that are within the IC manufacturer's parameters, then the Datron repair manual would be incomplete. Either the schematic would need to indicate that the part is selected, and why, or the parts list would need to.
