I have a faulty Fluke 707 laying around for quite a while, and after a closer inspection, I realized this unit has seen better days.
Someone has been here before, and they weren't exactly kind. A few ICs have been removed, and the pads along with them:
![](https://i.ibb.co/2qYzqn1/IMG-1430.jpg)
![](https://i.ibb.co/3W8bpgN/IMG-1434-arrow.jpg)
Many blobs of solder, poor technique, twisted components, flux all around, bodge wires.
![](https://i.ibb.co/c8y6727/IMG-1435.jpg)
![](https://i.ibb.co/c2vspwb/IMG-1436.jpg)
![](https://i.ibb.co/0X2nxHT/IMG-1437.jpg)
![](https://i.ibb.co/7JmL73k/IMG-1440.jpg)
![](https://i.ibb.co/zhV6hWs/IMG-1449.jpg)
C86, below the encoder, is missing. They soldered an upsized cap on the bottom:
![](https://i.ibb.co/0j4DQCB/IMG-1432.jpg)
I have not found any teardown so far. I need a couple of things to give this a try.
First, I need to check if the components are right, including the values of the passives. So I kindly ask if someone could share high-quality pictures of their board, with the IC markings visible, as well as the passives.
Also, if by any chance a good soul could measure the values of the caps, I'd appreciate it. The reason being, with all these blobs of solder around, I don't trust these are the right values, despite probably not being critical.
Of course, the best option would be a BOM and schematics, but we know we don't get that from Fluke. Maybe someone here did a reverse engineering?
![Roll Eyes ::)](https://www.eevblog.com/forum/Smileys/default/rolleyes.gif)
