Another update
A18 board is now completed (again) carbon comp resistors I missed last time have now been replaced with suitable metal film. A7, A8, A10, A15, A16, A17, A19, A20, A21 board are also all completed with new caps and resistors. WOW there is some dust and dirt on these boards! So all have been cleaned.
Broken GPIB connector on A21 board was replaced. I couldn't find the exact Amphenol part, so an alternative was used. This one had the bailey lock, but it was possible to drill out the rivets holding it and then left with normal connector. Blown relay driver was also replaced.
Backup battery on CPU board measures 3v, date/time are correct, but it may be worthwhile replacing anyway as I don't know when it was last replaced.
Unit was reassembled with following boards - A21, A20, A19, A18, A17 (and of course motherboard)unit powers up and works as expected with only limited boards attached. I made some voltage measurements for A19, A18, A17 boards (results attached) As you can see most of these are within tolerance, but a couple are out. In particular +5LHR and -5LHR warrant further investigation. Ripple on both rails is is 2.66v p-p (50hz)
I can see why it is a good idea to test these supply rails first before connecting any other boards. A bad supply rail could damage the other boards. This is why swapping cards willy nilly from a working unit into a faulty unit is a nice way to blow up working boards.
