Author Topic: SMD Component Identification Assistance  (Read 4397 times)
Offline GarywooTopic starter
« on: August 23, 2018, 01:49:17 am »
Hi everyone,
I've never had to decipher an SMD code before, so I thought I'd run my thoughts past you bunch of helpful folks to make sure I'm on the right track.
I've identified a failed SMD transistor (shorted) on an LED light strip controller PCB. The transistor outputs directly to the LED strip. There are 5 on the board, one for each colour channel (one removed in photo for testing).
The board runs on 24v from a CV 0.83A 20W power supply.
I'm pretty sure the component is a SOT-23 package. Length and width seem about right.
The markings on the component are WKC 72. I'm not quite sure which part of the marking is significant. I used this codebook as a reference. Initially I thought the WKC was the important part. This lead me to BCR119
However I'm not sure if this is right. If the 72 is the important part, then it could be 2N7002
The silkscreen designates the component with an M. MOSFET? I'm thinking the 2N7002 is most likely correct. Am I correct in my assumption?
Looking at octopart, they come in a variety of continuous drain currents. What would be a safe choice for my application?
Thanks for any help or advice ;D
« Last Edit: August 23, 2018, 01:51:20 am by Garywoo »
Offline SMdude
Re: SMD Component Identification Assistance
« Reply #1 on: August 23, 2018, 07:39:48 am »
I think you nailed it with bcr119.
Check page 10 of the datasheet, it has a breakdown of the smd code..
https://www.infineon.com/dgdl/Infineon-BCR119SERIES-DS-v01_01-en.pdf?fileId=db3a30431428a37301143f643b380286
Cheers
« Reply #2 on: August 23, 2018, 08:07:16 am »
Nice find SMdude!
I was a little unsure about the max collector current of 100mA with the bcr119, as that seemed a little low to me, so I was leaning towards the 2N7002 which comes in variants from 115mA to 1.4A.
Offline SMdude
« Reply #3 on: August 23, 2018, 10:48:03 am »
If you're ever unsure, pop an ammeter in and see what current the load draws, then it will be easier to sleep at night!
« Reply #4 on: August 24, 2018, 01:07:50 am »
I tested the current between one channel of the LEDs and the transistor, and read 315mA at full brightness.
As I mentioned, the BCR119 has a max collector current of 100mA. It's looking unlikely that it's a BCR119.
Does anyone else concur that it could be a 2N7002?
Offline amyk
« Reply #5 on: August 24, 2018, 01:57:23 am »
Not BCR119, nor 2N7002. If you Google pictures of those you will see why.
The former has literally "WKs", like this one where you can just make out the marking "WKs". Not WKC.
The latter does not have the "72" at vertical, and their mark is "12W". You can see themhere.
Now Google "WKC sot23" and you find... this. PMV20ENR. You will also find some other people asking what this part is, on the same LED strip as yours (a Philips Hue lightstrip, I presume?) with the same conclusion:
https://www.mikrocontroller.net/topic/443091
http://elektronikforumet.com/forum/viewtopic.php?f=8&t=91868
Philips/NXP/Nexperia are known to use the 3-letters + vertical date/batch code scheme. Here's a previous repair thread with a board full of them.
The following users thanked this post: Garywoo
« Reply #6 on: August 24, 2018, 01:38:52 pm »
Fantastic info, thanks so much amyk!
You are right about it being from a Philips Hue Lightstrip.
PMV20ENR looks to be a good match.
In that second forum link. I saw a suggestion of IRFML8244TRPbF as an alternative. They are a little cheaper, and since I have a number of PCBs to repair, and require ~50, it's a decent saving. Is this a sensible alternative?
« Reply #7 on: August 30, 2018, 10:56:40 am »
Ended up purchasing the PMV20ENR's. They worked perfectly.
Thanks again for the help!
