It is possible that the direction of polarization is not correct. You could check this roughly by rotating the film until you see the correct display colours.
It is possible that there a retardation layer missing in the replacement film, or present but not wanted. See
https://tinyurl.com/retardation-layer-1Let me know if I can send you a free sample with the retardation layer.
One issue is that you may have inadvertently peeled off the old film, but left the original retardation layer in place, which is almost impossible to detect.
I had a case where I spent a lot time trying to find the correct polarizer, and then discovered I'd not removed the old clear plastic retardation layer.
Therefore I had two retardations layers by accident.
After I removed the original retardation layer, the regular LCD polarizer worked fine. Just check that you removed all the film by checking the exposed layer is glass and not plastic....
.... except, if you can't get replacement film with the polarizer, you'd want to ensure the old retardation layer is in place so it can be re-used.
Of course, there may be no retardation layer at all.
This is a confusing answer I know, so if you do find the solution, please reply here so we can all benefit.
Also,
(1) Can you just buy a whole replacement display from Aliexpress etc?
(2) Have you tried to contact Tektronix for the information?
(3) Good luck...
When running into a similar problem, I got the following answer from
www.mecanusa.comI think it is also possible to send them a small sample of the original and they will try and figure it out.
-Pete
Thank you for contacting Mecan.
Here below link is for our lineups of retarder film.
https://www.mecanusa.com/polarizer/phasedifferencefilm.htmUnfortunately, we have no knowledge of the type of polarizer used in calculator
and we don't know which kind is appropriate for you.
If you would like a sample, we can provide small pieces for free.
Size is about 8 x 8 cm, and we will send you with regular air mail from our US office.
You may also want to try a circular polarizer.
A circular polarizer is made by laminating a linear polarizer and a quarter waveplate together,
so it might be that the original polarizer may have been a circular polarizer.
Here below link is for our lineups of circular polarizer film.
https://www.mecanusa.com/polarizer/circularpolarizer.htmUnfortunately, there is no self-adhesive layer in either product
Click here for our adhesive sheets for optical films
https://www.mecanusa.com/polarizer/adhesivefilm_MPD62.htmIf there is any other request or inquiry, please contact us anytime.
We look forward to your reply.
Best Regards
Ryo
