On the recommendation from video #1114 and what my needs are I purchased a TS80 about a year ago I have used it multiple times a day almost every day since i got it. It has been wonderful!
The problem came a couple months ago when the screen "backlight" when out. It was quite hard to read but still worked. Recently though the screen had got so dim that 90% of the time I am not sure if it is on or not.
I re-flowed the screen connector and most of the chips on the PCB. That did not fix the issue.
What I don't know now is if it is actually a screen issue or if it is something else. If it is the screen itself does anyone know where i can get a replacement (The screen model number is quite hard to read).
Thank you for any help. FK
