Author Topic: Record Player Turntable Motor not self starting  (Read 1643 times)
Offline spike1947Topic starter
« on: September 01, 2020, 09:47:04 pm »
Hi
I have a Sony DJ9000 Record Player and the problem is that the Turntable ( Platter) will not self-start, I have to give it a nudge then it will turn ok.
Anyone any idea as what the problem could be, have checked the motor winding's and they all show the same reading's, have re-oiled the bearing, it just seems that it just needs that initial power surge to start it turning, will attach a schematic and some pics of the underneath of the Turntable .
Cheers
Spike
Re: Record Player Turntable Motor not self starting
« Reply #1 on: September 01, 2020, 09:48:24 pm »
Pic 1
« Reply #2 on: September 01, 2020, 09:49:28 pm »
Pic 2
« Reply #3 on: September 01, 2020, 09:50:15 pm »
Pic 3
Offline rvalente
  • Country: br
« Reply #4 on: September 01, 2020, 10:26:24 pm »
Looking the provided service manual, did you check the motor coil and the hall sensors?
Checked voltages? Is the IC01 well supplied?
The following users thanked this post: spike1947
Online fzabkar
« Reply #5 on: September 01, 2020, 11:24:08 pm »
https://docs.rs-online.com/c720/0900766b80998f6d.pdf
Have you checked the 3.9 ohm 1W motor current sense resistor on pin #5 of IC01?
If you are game, you could add a second resistor in parallel and increase the current limit for the motor, if only for testing purposes.
Offline shakalnokturn
« Reply #6 on: September 01, 2020, 11:56:03 pm »
I'd check the power supply voltages and ripple because it can be worth the time spent.
First suspects would be C12, C14, C15 next IC1. I remember having to replace TA7259P's in Numark turntables that had mysteriously lost their punch.
Interesting to see that there are no Sony IC's in this turntable, is it a rebrand?
« Last Edit: September 02, 2020, 12:02:40 am by shakalnokturn »
« Reply #7 on: September 02, 2020, 12:14:34 am »
After checking the motor PCB looks very similar if not identical to that of the Numark TT-1650.
Doubtful it is a Sony design and most likely you'll need a TA7259...
Offline Haenk
« Reply #8 on: September 02, 2020, 07:15:48 am »
I'd start with measuring the 3 caps at "C03". I assume they are for one phase of the motor driver each - that's how Technics did it, and those caps often fail. Hall sensors and driver IC should be OK, as the unit runs...
However the fault might also be in the other caps (so check at the same time as the C03 ones) or motor driver IC (I would check out that one as last resort).
« Reply #9 on: September 02, 2020, 08:34:39 am »
Thanks for all your replies, will check those recommendations out tonight, and come back on what I find out ! .
Cheers
Spiike
Offline Gyro
« Reply #10 on: September 02, 2020, 10:52:07 am »
Yes, my bets would be on C02, C03 and C04 on the motor board having lost their pep too. That would definitely reduce motor torque.
Best Regards, Chris
« Reply #11 on: September 02, 2020, 01:33:51 pm »
Hi
Thanks for your reply, Re the IC 1 , can you tell me if all the numbers on that IC1 are voltages !.
cheers
Spike
« Reply #12 on: September 02, 2020, 03:39:00 pm »
Hi
Thanks for your reply, are the numbers on the sides of the IC01 voltages ! .
cheers
Spike
Online fzabkar
« Reply #13 on: September 02, 2020, 05:53:25 pm »
Yes, they would be voltages.
« Reply #14 on: September 07, 2020, 04:35:40 pm »
Any luck with the capacitors?
