I had one of these handed down to me twenty years ago. I decided I should try and get it working properly, and learn to use it.
![Tektronix 2213 tart-up 1943289-0](https://www.eevblog.com/forum/index.php?action=dlattach;topic=403923.0;attach=1943292;image)
It came to me from a lab at a university, and except for needing a good clean, it looks like it has led a good life. It's been sitting on the shelf collecting dust since I got it, save for the few times I've plugged it in to check that it "works", as in, produces a trace. It does, but it is quite faint, so I've mostly left it alone.
I've been able to obtain two versions of service manuals, one through Artek Media, another done by Zenith. One of these looks like the original from when the scope was first released. The other dates a little later, October 1982, and has some revisions included. Unfortunately, while close, neither of them seem to quite match the board in mine. I suppose revisions and variations happen when a product is made in multiple locations over extended period of time.
Things that I have been able to establish:
- based on the serial number this unit is British made (no letter B at the beginning of the s/n)
- serial number falls in the range for CRT grid bias voltage modification, but it hasn't been done
- it is equipped with a preregulator board rather than current limiting board type power supply
- there are no signs of any capacitor leakage or burnt components. Insides look quite nice, with some light dust collected in the 40 years
- it doesn't make any strange noises, nor does it run overly hot
- no magic smoke released
So nothing obviously broken. I get a relatively bright trace with beam find, and that makes me think there is life left in the CRT despite not receiving the grid bias modification to reduce voltage. I suspect some or all electrolytic capacitors are going low capacitance, or high ESR, probably both.
Investigation continues.
