If you read the question correctly, you will understand what I mean, actually, what I mean is very simple, taking the electric current from the USB socket to the connection socket
Those boards can often be found for peanuts in AliExpress.What about this short? Seems USB D+ and D- lines.Those diodes are just for ESD protection, not for power.There's a dedicated charger IC for that!
Quote from: DavidAlfa on March 25, 2023, 06:51:08 pmThose boards can often be found for peanuts in AliExpress.What about this short? Seems USB D+ and D- lines.Those diodes are just for ESD protection, not for power.There's a dedicated charger IC for that!They put 3 diodes, what was the need for this to pass the current to the opposite side, they could do it directly, the Chinese cuckolds made me try hard, but I connected a single point.
