First, thank you. I was hoping for some trouble shooting values but didn't know where to start. I'm meter poor and only had an old and cheap analog for backup. This is what I found. I'm guessing this is good news. But I'll defer to your conclusion.
RT1
1k scale: 1
x10 scale: 150
1ohm scale: 1k
fusible resistor
1k scale: 1
RV1: 1 ohm
RV2: open
RV3: 1 ohm
RT1 is a PTC and should measure around 1k ohm.
fusible resistor is 1k ohm.
RV are metal oxide varistors or (MOV) and should all read open.
I suggest desoldering RV1, RV2 and RV3. Measure them again out of circuit to see if RV1 and RV3 are completely shorted.
With RV1, RV2 and RV3 removed, does resistance measurement work now? Try measuring a 100 ohm, 1k ohm and 10k ohm resistor. Try shorting probes and continuity.
PS. BTW, you didn't answer what a 1.5V AA cell reads on DCV.
