Author Topic: Samsung Galaxy S5 no sound  (Read 1241 times)
Offline CalifaunaTopic starter
« on: January 03, 2022, 08:34:46 pm »
Hi again,
I have an S5 which produces no sound through either the top or bottom loudspeaker. The top loudspeaker produces a constant, very faint high pitched squeal.
I have tried:
1. Using the housing of another S5, as this housing contains the top loudspeaker.
2. Replacing the bottom loudspeaker with a new one.
The symptoms do not change after the above changes. The phone works fine apart from this.
I have a soldering station, multimeter, hot air gun, handtools, etc.
Thanks for any troubleshooting and repair help.
Offline abdulbadii
Re: Samsung Galaxy S5 no sound
« Reply #1 on: January 03, 2022, 09:08:44 pm »
Have tried all the S/W ways instead ?
esp. device reset
The following users thanked this post: Califauna
Offline SilverSolder
« Reply #2 on: January 03, 2022, 09:14:53 pm »
When you reboot the phone:  Does it make normal sounds during the boot phase?  (Many phones give a little melody while booting...  Hopefully yours does!)
« Reply #3 on: January 04, 2022, 04:29:33 pm »
There is no boot jingle when turning on the phone. The faint squeal is there as soon as the device is turned on.   It has Lineage 9 installed.
Software fixes I have tried include a full reset.
« Last Edit: January 04, 2022, 04:32:55 pm by Califauna »
Offline bob91343
« Reply #4 on: January 04, 2022, 06:31:01 pm »
I finally gave up on my S5.  Its battery kept running down (even changing batteries didn't help).  Now I use it to play games and see the weather report.
I replaced it with the A42 5G (or is that A24 5G) and it's a lot better.
« Reply #5 on: January 04, 2022, 08:21:35 pm »
I've found that actually the ear speaker is working (not main speaker though). Turning up the 'in call volume' in setting I can hear it over the squealing sound. No such luck with the ringer volume, or playing music/Youtube videos though, which produce no sound at all through the main speaker.
Offline bob91343
« Reply #6 on: January 04, 2022, 10:31:44 pm »
Plug in external earphone and see what you get.  Oh, I mean hear what you get.
Offline abdulbadii
« Reply #7 on: January 05, 2022, 01:38:49 am »
There is easily Samsung Galaxy S5 schematic online https://www.simplecodehub.com/2016/05/schematic-diagrams-samsung-galaxy-s5-sm.html?m=0, just narrow down to audio output try to get V or I since there's hint earphone line one works
« Last Edit: January 05, 2022, 10:45:09 pm by abdulbadii »
« Reply #8 on: January 05, 2022, 09:27:26 pm »
SOunds works OK through headphones output.
« Reply #9 on: January 06, 2022, 02:38:37 pm »
I have found out that the MB is completely missing a 'Low frequency filter' component. It must have fallen off at some point.
Anyone know where I can get one of these?
EDIT:  According to the service manual this component is an 'inductor', and from what I gather is the same component as the one next to it. Seems to be possible to buy this component online if you search for the part number (2703-004597).
https://mega.nz/67a9bdf9-8fff-449f-95a6-f5937fdda781
I guess if you have two S5s you could transplant one to the other (to the detriment of your other S5 of course).
If it is a filter I'm not sure why it would be a low pass filter (inductors behave as low pass filters don't they) rather than a high pass filter, but at any rate this guy seems to have bridged the contacts and his speaker works:
« Last Edit: January 06, 2022, 03:49:25 pm by Califauna »
Offline abdulbadii
« Reply #10 on: January 06, 2022, 11:14:45 pm »
Just try to get correct Samsung Galaxy S5 schematic then mark it or point out the need and upload here to be discussed and solved together.
