Author Topic: Keithley TF-245 Bodge  (Read 299 times)
Offline ApertureScienceTopic starter
« on: July 14, 2024, 07:04:01 pm »
I have another Keithley 2000 with a broken TF-245 resistor array (pin 4-14 30k).  I wrote Tektronix Support, but I want to have a plan B. In my case only one path is broken, so im considering putting another low tempco resistor on top. Any recommendations? I was looking at WELWYN - PCF0805 5ppm surface mount or two NOS Alpha Electronics (20k+10k 5ppm) in series. Those seem to be readily available at 20 Euro for both options.
Offline Kleinstein
Re: Keithley TF-245 Bodge
« Reply #1 on: July 14, 2024, 07:14:16 pm »
Ideally one would like to have matching between the 3 x 30 K resistors. So 1 good external resistor may not be good enough. It is a bit unclear if the 3 resistors should have the same value of maybe a bit different.
For 3 matched resistors I would consider 2 x NOMCT 10 K (or 20 K) using 6 + 3 of the resistors.
The following users thanked this post: ApertureScience
« Reply #2 on: July 15, 2024, 07:56:40 am »
Thank you for the suggestion! I hope the spare part will be in stock, ill post once tektronix has replied back to me.
Online coromonadalix
« Reply #3 on: July 15, 2024, 11:20:33 am »
there is a project to substitute it  here on eevblog  ....
