Author Topic: fluke 114 - chipped edge of lcd, missing bottom lcd 'leg' on display  (Read 861 times)
Offline wornoutwordsTopic starter
hey all
i have a fluke 114 where the bottom "leg" of the number display is missing
i initially thought that rubber connector thing between the circuitboard and lcd was dirty, but it turns out the edge of the lcd glass got chipped and it's broken one of the connections
any suggestions on what i might do to fix it?
I've cleaned out the shards of glass hoping it was them interfering, but not such luck. I think if i can somehow bridge the connection it should start working ok, but i dont want to jam metal in there as its glass
Offline tunk
  • Country: no
Re: fluke 114 - chipped edge of lcd, missing bottom lcd 'leg' on display
« Reply #1 on: February 04, 2021, 02:44:13 pm »
Never used it myself, but you could try conductive paint.
« Reply #2 on: February 05, 2021, 12:59:58 am »
thanks, hadn't thought of that.
I've tried a strip of aluminium foil but that didn't work
Online bdunham7
« Reply #4 on: February 08, 2021, 11:51:24 am »
it turns out its only 30 bucks for a new lcd from the local fluke repair place.. cheaper than a tube of the silver ink here in aus
thanks for the suggestions!
« Reply #5 on: July 06, 2021, 07:47:09 am »
in the interest of closure, i finally got the replacement lcd (i ordered it back in feb - they had covid delays getting fluke spare parts into aus) & it's all working again
The following users thanked this post: robert.rozee
