I bought a Parkside Cordless Soldering Station 20V PLSA 20 Li B2 as a spare to use away from home.
First experience was OK but slightly alarming, as the heat was up to seemingly bonkers levels, around 500 deg C, with all the flux burning off. On second use the tip disintegrated! I'd read the review and fix for the earlier A1 model, but didn't know that the B2 model was different.
AAAnywwwayyy! Read a load of stuff on the internet and one person seemed to identify the appropraite wires, but chose a resistor which still set the tip temp too high. Another suggested a higher value resistor. Here's my 'amalgum' of the two and notes about the changes it creates in use. Its pretty simple.
The unit will react differently (see later), but with a bit of common sense is usable and an improvement, operating at about 350 deg C.
In short, you need a 47 Ohm, 1/4 watt resistor, soldering iron and (seemingly) leaded solder, plus heat shrink and some thin protective sleeving made of woven glass fibre (which are present in the electronic 'personal fuming devices' so liberally scattered around our blessed land).
Here's what I did:
1. Disconnnect from the battery.
2. Take off the end the soldering iron by removing the large plastic nut
3. The nut enables the metal iron tip assembly to be removed by CAREFULLY sliding off.
4. Underneath is a very breakable ceramic heating element assembly - so be very careful with it!
5. Push the flex into the handle which will slide the ceramic tip and circuit connection board out of the handle fairly easily.
6. Identify the white ptc wire (white and black are PTC wires)
7. Desolder the white wire so it is free of the board
8. Cut the white wire a little shorter to accommodate the resistor length, so that when the resistor is soldered in series onto the wire end, the other end will go down the hole you originally removed the white wire from. Now older resistor to wire end.
9. Slip heat shrink (and shrink), then grp sleeve, over soldered connection
10. Re-solder resistor in place so it is now in series with the white wire ontothe connector pad.
11. Re-assemble in reverse order.
Things that seem to change:
a/ The unit will not switch itself off - I guess because the PTC detects (positive) changes in resistance as it heats, it expects these to drop to zero before turning off. Since you've put in extra resistance it will never drop to zero, so therefore won't automatically switch off. Common sense implication: leave to cool then disconnect from battery.
b/ By the same token, putting in extra resistance to achieve a lower (350 deg C 'ish) tip temperature will fool the PTC sensor into thinking its up to temperature earlier than it actually is when starting and the light goes green. Common sense implication: wait a bit and check when the solder melts!
Hope this is useful to others, I could have done with the info when I got the unit.
