Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Find Replacement Component/Component Identification for FLIR T4xx/B4xx Camera
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Find Replacement Component/Component Identification for FLIR T4xx/B4xx Camera (Read 1385 times)
Chanc3
Frequent Contributor
Country:
on:
April 12, 2016, 02:50:20 pm »
Hello everyone
I've stripped down a B4xx series camera today as the operator was complaining that the down movement on the joystick was not working. Upon further investigation, it does work correctly if you apply a little bit of pressure and lightly tap down. I took apart the camera to identify the component as I believe one of the internal contacts is failing - funnily enough, this is the 3rd or 4th T4xx/B4xx I have seen with a broken joystick. I'm not an electronics expert, so don't know the correct terminology to use when looking for parts, so I'm hoping someone here can help identify the joystick I need to replace - please see the photographs below:
Logged
Chanc3
Country:
Re: Find Replacement Component/Component Identification for FLIR T4xx/B4xx Camera
Reply #1 on:
April 13, 2016, 10:28:36 am »
Few hours later, it turns out I should have been looking for a 5-way navigation switch!
eBay link here for anyone interested:
http://www.ebay.co.uk/itm/361471159344
Part number is: SKQUDBE010
Alps Navigation Switch , 5Way , SMD
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
