Hello, hello, I recently acquired 7 FG-8002 function generators. All not working... a bit sad at first, but they were cheap so I took them all. They are Keithleys or Helwett Packards, but they work somewhat well.
All the units had a similar problem, just a high output signal. I cracked it open, first thing I noticed was the disintegrating rubber feet. Nice and crummy. I traced things back to a burnt LM324. On the first unit I took apart it had some discolored pins I didn't notice until I replaced it, but on the other units the op amps had died in a fascinating fashion. One of them had the plastic blown of the top. I replaced the IC and everything seems to work fine. I don't get anything heating up unusually.
Now my question is what could have caused the device to fail? Is it a user error that caused a fail in most of these and they were phased out because they had a pile of them (previous owners, used to belong to a university). Or is it a common failure across the units?
-Thanks, at least there are some pictures for those of you who look for those
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
