Author Topic: Faulty DSE D-3800 Power Supply, similar to Manson EP-925  (Read 14982 times)
Offline RaffTopic starter
Re: Faulty DSE D-3800 Power Supply, similar to Manson EP-925
« Reply #25 on: January 11, 2020, 10:31:22 am »
It was a while back I repaired my power supply, but from memory you have to desolder the meter pins on each meter to get the board out.
Be sure to check your meters are nice and free to move, mine were sticky and I got the "Volts" one working fine, but the "Amps" one is still sticky, having to desolder, yet again, those meter connections puts me off repairing it for now :)
Regards,
Raff.
The following users thanked this post: Steamer61
Offline bigpimp347
« Reply #26 on: November 30, 2021, 11:49:01 am »
seems this thread may just help me out..
i have a EP-925 which is high voltage, easy fix, the 3055 fail..
but i have a similar unit sold as a Watson W-25AM and this is only showing up to 7v output,
it varies fine down to maybe 2v.
after remove years of fag smoke stained dust and getting air circulation i started to look in to it but couldn't find any obvious,
this thread has many good points i will now check.
i'll report back once  i have/if i repair it..
BUT here's one, what about an EP-925 that fails to switch on randomly ??
works fine majority of the time, other times just won't fire up ??
Offline TheBay
  • Country: wales
« Reply #27 on: November 30, 2021, 10:58:52 pm »
The W-25AM is a different design to the EP-925, these use a LM358 opamp for voltage regulation.
Check, clean or replace the voltage adjustment pot on the front as these are common to fail (I remove them and fit an internal resistor or pot), so are the open skeleton adjustment pots on the main board so check those too.
Check the obvious like the series pass transistors and drive transistor. But I wouldn't be surprised if it's the front voltage pot.
Odd fault with the EP-925, try switching it on and off at the wall to rule out the switch on the front of the EP-925, it could also be a dry joint somewhere on that horrible PCB that's attached to the front.
Check if there is any power on the primary/secondary's of the transformer when it doesnt fire up, then check the bridge rectifier and the aux output which is half wave rectified on the main PCB.
« Last Edit: November 30, 2021, 11:03:37 pm by TheBay »
