Author Topic: Fault PTC - help identifying replacement  (Read 872 times)
Offline 5m3g_headTopic starter
« on: February 18, 2023, 09:34:08 pm »
Hi , I was wondering if anyone could help me identify a part, or recommend a suitable value to replace with.
Recently my beard trimmer started to display a fault where it only ran for 30sec before grinding to a halt. I suspected the battery as the unit is old.  However after replacing the cell, the device had the same issue.
After poking around of a while I discovered that the PTC right near the positive to the motor was faulty. I would like to replace it, however Im not experienced enough to know what value to use.
The device is a Remingtion MB6550 and it runs a single 18500a Li-ion cel.
I've attached a photo of the faulty component, does anyone have any suggestions for me ?
Online Original
  • Country: gr
Re: Fault PTC - help identifying replacement
« Reply #1 on: February 18, 2023, 11:00:35 pm »
The following users thanked this post: 5m3g_head
Offline R-1125F
« Reply #2 on: February 18, 2023, 11:16:02 pm »
« Reply #3 on: February 19, 2023, 05:08:09 am »
 Two Thumbs up ! thank you both for your help.. I get one ordered.
Cheers.
Offline floobydust
« Reply #4 on: February 19, 2023, 05:13:21 am »
Also note the PTC might be okay, it's that the motor current has gone high due to mechanical issues or lack of lube.
I use oil 20W for the motor, and molylube in the mechanism. PTC fuses do get softer everytime they trip.
« Reply #5 on: February 19, 2023, 10:08:55 am »
Thank, I'll make sure I clean and lube it up when I replace the PTC.
Offline R-1125F
« Reply #6 on: February 19, 2023, 01:50:01 pm »
You might want to test the circuit before ordering the part.  I don't think it would hurt to jumper the PTC for testing.
LCSC carries the part.
« Reply #7 on: February 20, 2023, 05:59:21 am »
Cheers, that's exactly how I tested it.
Jumped the PTC and shaved my beard  ;D
Pretty confident the PTC will fix it, but I'll still give it a good clean and lube.
« Reply #8 on: April 01, 2023, 09:49:20 pm »
For anyone following along at home. I replaced the PTC with the one linked here, lubed the blades and the shaver is in A1 working condition.
I have used it 5 times since, and charged it.. all good.
Thanks all on here for the help.
Offline floobydust
« Reply #9 on: April 01, 2023, 10:03:46 pm »
That's great, shaver prices are ridiculous nowadays. Remington fuse Alpha-top SMD1210-200 rated 6V 2A hold 4A trip, 8A 1 sec.
Same as Littelfuse 1210L200 or Bourns MF-USML200/6 is close.
