Thought I would ask, before giving up. I have a Roberts dab radio RD 27 model, it has an LCD dot matrix display. The radio is quite old when I acquired it, and it has fading dots in the matrix. When the radio is cold, and first switched on the display is fine, no visible fading, but when it's warmed up, the display shows some fading on the matrix segment dots. I was wandering if it's repairable. The one anomaly that puzzle's me is when it's switch on from cold, the display matrix is totally fine. I would have thought if it's a failing display, it would be degraded segment matrix dots from start up. Could this be a capacitor problem with the LCD display. Any ideas to look at appreciated. And Thank you for reading.
